Oil pump coupler replacement
joe
12-15-2002 06:00:50
I have a 54 B that the oil pump coupler is striped since it's not turning the gear with the long shaft. this coupler looks like a half inch 4 corner socket. How do I go about getting the old one down and getting the new one up there? Do I need to pull the whole pump body because the coupler is to big to go up through the hole that the shaft comes out of.It looks like in the parts break down that there are two oil lines with compression nuts that will need to be removed to pull the whole pump body down. Any suggestions?? tTHANKS
MikeH-Tx
12-15-2002 10:09:34
 Re: oil pump coupler replacement in reply to joe, 12-15-2002 06:00:50
Joe, the AR that I am working on had a 1/2 drive socket in place of the coupler. It was a Snap-On, so I just left it alone after making sure it wasn't going to hit anything.
Clooney
12-15-2002 11:06:50
 Re: Re: oil pump coupler replacement in reply to MikeH-Tx, 12-15-2002 10:09:34
Mike, that socket might be ok in a warm climate like Texas but if the tractor is used in below freezing areas it should have the correct coupling. That drive coupling is like a fuse & designed to break easily if the oil pump is stuck due to water freezing in it so the pump & drive gear doesn't get broken or damaged.
Joe Crow
12-15-2002 09:09:49
Joe now might be the time to find out why the old shaft broke.
Clooney
12-15-2002 06:15:01
Joe, pull the crankcase cover then pull the oil pump cover & drop the long drive gear down enough to replace the coupling through the crankcase cover area. The old coupling is probably broken & laying in the bottom of the crankcase....
joe
12-15-2002 08:50:07
 Re: Re: oil pump coupler replacement in reply to Clooney, 12-15-2002 06:15:01
There inlies the problem I can look up with a light and see the old one is still up there in place. I need to get up there to pull it down and theres not much room to get any thing up there and aalso see what I'm doing. Thanks for responding
Jerry S
12-17-2002 08:41:50
 Re: Re: Re: oil pump coupler replacement in reply to joe, 12-15-2002 08:50:07
Joe, if you are looking up and can see the coupler, you must be looking through the oil pump. You need to get the crankcase cover off of the top of the motor right between the flywheel and the clutch pulley. You can access what you need in there and see all you need to like Clooney said. While you are there, you can fish any metal pieces or clean the oil sump screen inside the crankcase.
