Pulloff
Jeff
01-01-2003 17:00:10
what do u think will win in a pulloff, a johndeere B, or a farmall M ..the B has a straight pipe on her so shes got more power than stock...
Kid
01-02-2003 15:13:09
 Re: pulloff in reply to Jeff, 01-01-2003 17:00:10
Being young, I've tried this. I took my M, and I out pulled the neighbors G, grant it, the ole M is running about 44hp, but a B against a good M, hasn't got a chance. Watched my dad take our Super H and out-pull a A. I like both, but you have to give those ole Farmalls credit, they can run.
Dave 2N
01-02-2003 11:24:20
The JD B is a great old tractor but in this instance, it's no match for a Farmall M.
Scott
01-02-2003 11:02:15
Remove the "straight pipe" from your B and park a G under it and you may have a better chance against the M.
CLW
01-01-2003 20:04:29
There are some things the B won't do. The M being one of them.
CLW
B Man
01-01-2003 17:50:22
If you can't figure out who would win by sizing up the two tractors, than go for it.
JD JACK
01-01-2003 17:46:11
A JD G and Farmall M is a equal pull. Your b should be match against a C or maybe an H.
Dave 2N
01-02-2003 11:26:14
 Re: Re: pulloff in reply to JD JACK, 01-01-2003 17:46:11
The B would probably outpull the H but believe it or not, it might have a harder time against a Super C.
ChuckW
01-01-2003 17:12:20
better leave your B at home....have seen good Super M Farmal eat lunch on 60's.
2 cylinder
01-01-2003 18:20:26
 Re: Re: pulloff in reply to ChuckW, 01-01-2003 17:12:20
A JD-60 should not be compared to a Farmall Super-M, it is the competitor of the Farmall-M, or 300-350. A John Deere- 60 is an updated version of the John Deere-A. Comparing a 60 John Deere to a Super-M Farmall is like comparing a John Deere-G to a Farmall-H. Your comparing apples to oranges instead of apples to apples. Although I think the JD-60 does better than some of you fella's give it credit for, and I've worked fields with the both of them.
earlschieb
01-01-2003 17:32:20
You have got that correct, my step dad give me a lesson about that stuff one day, only it was his H Farmall versus my 51 B John Deere, he drug me around like I was a hay wagon, we tried it 3 times with the same result.
mike
01-01-2003 17:37:32
 Re: Re: Re: pulloff in reply to earlschieb, 01-01-2003 17:32:20
The M is four cylinder and B is two, so to be fair take two plug wires off the M nd see what he does then. Fair is Fair
