1st B with Water pump
Farmboy 2
01-05-2003 07:09:34
What number was the first B with a factory water pump?? When did the square axles start?? THANKS
Ron
01-05-2003 12:53:03
 Re: 1st B with Water pump in reply to Farmboy 2, 01-05-2003 07:09:34
Many were updated to waterpumps.....ours were used in a mounted 226 cornpicker, and overheated, until the waterpumps were installed...
Rich
01-05-2003 08:12:06
Farmboy 2,
Ser.# 248290 was the first square axle..... ....Ser.# 306600 was the first water pump.
Aaron
01-05-2003 10:47:30
 Re: Re: 1st B with Water pump in reply to Rich, 01-05-2003 08:12:06
I have B s#305272 with a water punp that looks factory. Was this an option at this time or was it added on?
Thanks Aaron
Rich
01-05-2003 14:22:48
 Re: Re: Re: 1st B with Water pump in reply to Aaron, 01-05-2003 10:47:30
Aaron,Your pump was added later..... under certain conditions the tractor would overheat....so the first chance they had.... a pump system was added. The way we used our "B" it never had overheating problems without a pump.
gwh
01-05-2003 07:25:29
Farmboy2, The part book list SN 3066000 as the first # w/water pump and list the clamshell fender which was designed for the square axle at SN 260984. gwh
