1010 PTO question/ value???
larry
01-05-2003 09:44:16
I am looking at a 1010 gas Utility, a 1961. It has a small PTO lever mounted on the tranny, like a 430. I have never seen this,only the big hand lever mounted on the left side by the seat. Is the small one correct?? The 1010 has power steering, 5 speed,float ride seat, fenders, headlights, dual 3 point set, rear remotes,good sheetmetal, and orginal rubber. What would this old girl be worth??
ChuckW
01-05-2003 10:30:52
 Re: 1010 PTO question/ value??? in reply to larry, 01-05-2003 09:44:16
live power has a large flat lever from the left side of the transmission...also early 1010 had the dash shifter(a real problem item). They also had a 430 rear end. The later models had a heavier rear end. I had an improved 1010 1965 model and it was as good as they came, but it did not have any low end torque, had to keep engine reved for any power. I've had a lot of JD's and the 1010 was one of their failures/should never have been made.
JD
01-05-2003 10:20:04
The 1010 your looking at has transmission driven PTO. The lever on the side of the seat like your thinking about is for independent (live) PTO.
Are you sure you want to buy a 1010?
The 1020 or 1520 is much better.
