3020 Wet Brakes
Jim C
01-13-2003 14:16:57
We have replaced all the brake pads and bled the brakes the way the JD shop manual said to do, but I don't have any brakes. The steering,pto and hydraulics all work ok. Any suggestions?????
davidval
01-14-2003 06:02:31
 Re: 3020 Wet Brakes in reply to Jim C, 01-13-2003 14:16:57
if the brakes worked before the brake pads renewal, and if the pistons were assembled correctly with new orings and paper backup rings,maybe you removed the bleed screws.if the bleed screw is removed,thre is a steel ball behind it that may fall out. if it falls you can't plug the bleed bassage and brake pressure is lost.
by the way the brakes work on the high pressure system.
david
Jim B
01-14-2003 04:46:03
Jim C,did you replace the orings on the pistons that operate brake pads?Did you renew both sides?The brake valve operates off of the trans.pump if I remember correctly.Jim B
Jim C
01-14-2003 06:02:57
 Re: Re: 3020 Wet Brakes in reply to Jim B, 01-14-2003 04:46:03
Yes we replaced the O rings and the paper washers for the pistons,replaced all six brake pads in both sides. I think my next step is to get the kit for the brake valves and rebuilt them.
Brad
01-14-2003 12:59:48
 Re: Re: Re: 3020 Wet Brakes in reply to Jim C, 01-14-2003 06:02:57
I have got a brake valve overhaul kit still new in teh box.
bl4440@schallertel.net
Brad
