John T, Sorry to hear about the complications you had. No matter what version of Windows you have, whether it was purchased as "Full" or "Upgrade", they can all do the same things. The Upgrade version can be used to perform a clean install, but it will require you to enter an old Windows CD for verification. Either way, to do a clean install: boot to a DOS prompt and run \i386\winnt.exe from your CD-ROM. To perform an upgrade, run \i386\winnt32.exe from your CD-ROM while in Windows. When upgrading from a 9x operating system to an NT OS, I always recommend performing a clean install because you will eventually end up having lots of compatibility problems with one thing or another. I use two hard drives so that I am able to keep my operating system and programs seperate from my data. You will have to re-install your programs along with your operating system, but losing important data will not be a problem and you don't have to struggle with deciding on whether you want to "upgrade" so you can easily retain your old stuff (but run into problems), or do a "clean install" with little or no errors (but you may lose some data). When installing Windows XP, you will have to decide on what file system to use. FAT32 is the most compatible, but also the most vulnerable. NTFS provides support for larger drives and gives you file level security. Overall my feeling is... if you're installing a new operating system, you might as well use all the new bells and whistles by doing a "clean install". Windows XP has features not present in previous "Home" operating systems because it is built on NT technology which is known for it's reliability and stability in the work place. The hardware abstraction layer alone is worth it because single programs will not be able to crash the entire operating system. The NTFS file system introduces higher security standards into the home which is necessary with computers and the internet becoming more and more popular. Doing an upgrade can implement these features, but I've found they're not as reliable when upgrading from 9x. Oh well. Good luck in the future! Hans Geisterfer Microsoft Certified Systems Administrator
