2010 --locked up right rear wheel
Richard in Kans
01-19-2003 13:06:35
My 2010 JD, 1965 model has a locked up rear right wheel. It ran ok when I put it in the shed about a month ago. Today that wheel won't move. I've pulled and pushed it backwards, the wheel won't buge. I've had past problems with the brakes freezing so I took the right brake off-- didn't make any difference. The battery was down and that's the reason I was pulling it. The other wheel rolls just fine. I tried neutral and different gears-- no good. Any thoughts from this board as to what might be happening? Thanks.
Tom in Mo.
01-19-2003 16:12:49
 Re: 2010 --locked up right rear wheel in reply to Richard in Kansas, 01-19-2003 13:06:35
Sounds like it's time to warm it all up and replace all the fluids. If there's enough water in the case to lock up the axle, then it's time for a drain and fresh lube.
Richard in Kansas
01-19-2003 20:20:12
 Re: Re: 2010 --locked up right rear wheel in reply to Tom in Mo., 01-19-2003 16:12:49
You're right there! I haven't changed rear end oil in the 15 years that I've owned the tractor!
Mguy
01-19-2003 15:38:30
Ice, ice, baby! It's froze.Mguy
Richard in Kansas
01-19-2003 15:52:29
 Re: Re: 2010 --locked up right rear wheel in reply to Mguy, 01-19-2003 15:38:30
You just might be right! I pushed it into my heated shop and after I got it started about an hour later I drove it right out! Works fine now! Wonders never cease!
Mguy
01-19-2003 16:01:51
 Re: Re: Re: 2010 --locked up right rear wheel in reply to Richard in Kansas, 01-19-2003 15:52:29
Richard, now that you got it loose, keep it in and thaw the ice all the way. Then you can crackthe drain plug,CRACK I said,and drain the water from under the oil. Thawin'a tractor out can take some time.....Mguy
