2010 engine swap
Farmuse
01-24-2003 08:17:02
Are there any newer engines that can be swapped into the 2010 tractor, That are bolt in swaps?
Ray
01-25-2003 16:50:42
 Re: 2010 engine swap in reply to Farmuse, 01-24-2003 08:17:02
I had a 2010 diesel dozer dud engine good tractor I wish I had put gas combine motor in it I finaly got tired of putting head gaskets on it and sold it
Mark
01-24-2003 13:03:16
There are no direct bolt ins for a 2010. Unless yours is blow to pieces you would be better off rebuilding what you have
farmuse
01-24-2003 13:41:33
 Re: Re: 2010 engine swap in reply to Mark, 01-24-2003 13:03:16
Are there any aftermarket rebuild partsfor it? The complete parts list from JDis more than the tractor is worth!:)
Rick Sharp
10-12-2003 19:44:51
 Re: Re: Re: 2010 engine swap in reply to farmuse, 01-24-2003 13:41:33
JOHN DEERE 2010 GAS Engine Overhaul Kit $962.00
Includes: pistons, liners, rings, piston pins, piston pin retainers, rod bearings, main bearings, thrust bearings, piston pin bearings,
gasket set, front crankshaft seal, rear crankshaft seal,
Thank you for your request, Bob Parts Supply Corporation 4700 118th Ave Fennville Michigan 49408 USA PHONE 800 448 5345 / 269 673 4146 FAX 800 448 3897 / 269 673 7226 email: sales1@parts-supply.com
JWH
01-24-2003 18:03:19
If your 2010 is a gas-burner, your other alternative is to find a 45 combine (prior to 1967) with a good engine---preferably with an engine serial number above 30,000. These 145 power units are a bolt-in swap for your 2020 engine---in fact, they are the same engine, for all intents and purposes.
JWH
01-24-2003 18:04:56
 Re: Re: Re: Re: 2010 engine swap in reply to JWH, 01-24-2003 18:03:19
Ooops!! I meant to type 2010 engine!! Sorry!
Tom in Mo.
01-24-2003 15:23:01
Hello Farmuse, I rebuilt the top end of my 2010 three years ago and at that time just the sleeve plate cost $450. The total for everything above the crank was nearly $900. It runs great now!
This is a hard call to make whether to scrap it or save it. If you like it a lot then save it. If it's just a tractor, replace it. You should also factor in the tires, brakes, clutch, etc.
