800 hitch part on ebay
Joe
02-02-2003 18:07:11
anyone know the value of this part? item number on ebay is: 2402297045
ChuckW
02-02-2003 18:39:01
 Re: 800 hitch part on ebay in reply to Joe, 02-02-2003 18:07:11
purchased one of these a few years ago, gave $500. They're hard to use unless you stabilize the arms and make a center link bracket. The original setup is not very functional so I modified my unit.
Dean A. Van Peursem
02-02-2003 19:35:24
 Re: Re: 800 hitch part on ebay in reply to ChuckW, 02-02-2003 18:39:01
third party image
Actually the two upper arms of the 800 series hitches can be used in a manner that closely emulates a single top link in a conventional 3 point hitch.
Just remove the evener bar and attach each upper arm on the oustside of the implement masthead and run a pin through all three pieces. Works quite well.
There are three different versions of the 800 hitch - 800, 800a and 801. 1953 to 1955 and then there was a 801 upgrade kit to upgrade the 800 and 800a to an 801 so you will see all kinds of configurations of these hitches. There are three different versions of the crank arms that attach to the rocker arms as well.
For pictures of all these hitches and associated implements see:
Link
