1952 JD Model M rear rims/tires
Russ Fox
02-11-2003 13:59:18
I am currently restoring a 1952 JD Model M that came with 11-26 BF Goodrich Silvertown R-1 rear tires. I believe the factory tires were 8.0X24's. I am hoping that someone may be able to shed some light on new replacement rubber as the 11-26 size appears to be quite hard to come by new or used.
Clooney
02-11-2003 14:12:28
 Re: 1952 JD Model M rear rims/tires in reply to Russ Fox, 02-11-2003 13:59:18
Russ, true most M's came with rear 24" wheels. I do show in my manual a 26" was offered. You will have a hard time finding 11-26 as that is the old size used when tires were measured differently than they are now. The 11-26 tire size is now replaced by a 12.4-26.....
