Tractor Memorabilia Discussion Forum
JD Pedal Tractor
Loren
12-08-2003 20:46:48
Need help finding somewhere to have this repaired (if possible). I have a mid 50's JD pedal tractor. Was rebuilt several years ago (new bearings, tires, chain, paint, etc.). It matches the 56 JD "60" I have in the garage. I probably should not have, but I let my grandkids, nieces & nephews ride it around the driveway. Driveway has a hill on the back side. Well, it got away from one of them, went down the hill and hit a tree. Broke the cast housing on the left axle. Can this be repaired (welded), and if so where? Not planning on selling it, as my grandfather gave to me for Christmas when I was 5 yr. old.
Loren - Minnesota
12-10-2003 21:03:02
 Re: Re: JD Pedal Tractor in reply to Stan - Florida, 12-10-2003 19:24:28
Thanks Stan. I'm in southern Minnesota, and own a place in Largo, FL. Have contacted Samuelson's. They have the axle housing, but mine broke where the axle bolts to the main body. Will contact them again to see if they have that part. Again, thanks for the advise.
Randy
12-11-2003 04:00:15
 Re: Re: Re: JD Pedal Tractor in reply to Loren - Minnesota, 12-10-2003 21:03:02
You may want to try Tom Magnuson pedal tractor parts
He is located near Madison, Wisconsin. He has all the parts and he does the welding. his # is (608)437-5061 or email TMagpedal@aol.com
