Lift quit on MF65
DP
05-21-2001 06:07:25
After changing fluid in tranny, the lift quit.
I used a quality tran fluid.
Its a 1958 model with no filter. Any ideas??
jeff
06-04-2001 17:18:01
 Re: Lift quit on MF65 in reply to DP, 05-21-2001 06:07:25
I think your tractor does have a hydraulic filter it should be underneath at the back two small bolts to remove the cover or you might find it behind the hyd dipstick plate small strainer screen just rinse with a cleanining solvent,did you use trans/hyd fluid or tranny you should use tran/hyd let me know if this helps
