Hardstarting MH50
Alden j Durant
02-11-2001 19:28:06
My 1956 MH50 runs good and has good power but will not start. I have checked points, timing, etc. If you pull the plugs, turn over the engine several times and put the plugs back in it will start right up. This is not trying to start it warm but after it has set overnight or for several days. It will not catch at all unless you pull the plugs and do this. I could see this if it was warm and flooded but this is not the case. What could be wrong? Is it fuel or fire? Like I said runs great once it fires and catches.
Paul in NM
02-12-2001 16:26:34
 Re: Hardstarting MH50 in reply to Alden j Durant, 02-11-2001 19:28:06
Alden - did you replace the condensor?
Paul
