180 Problems
LP
02-14-2001 08:39:37
I have 2 questions about my 180.
1. Decided to check hyd.pressure on my remotes and the gauge showed about 600 psi. I have not noticed any problem with the lift arms,do I have a dirty filter or another problem?
2. The rear wheels are starting to look like this
\ /, and the right wheel seems to be out balance in high gear,I have power shift rims and they appear to be on correctly, any ideas as to what has caused these problems?
timbo
02-15-2001 12:39:52
 Re: 180 Problems in reply to LP, 02-14-2001 08:39:37
Your wheels probably need adjusting to do this jack the rear wheel slightly off the ground and set a can about 1/2 inch from the tire and with the transmission in neutral rotate the tire by hand. Loosen the ramp bolts on the wheels slightly and where the tire runs out at the can tighten the bolt nearest the spot where the tire runs out. Repeat this until the tire runs pretty true. Make sure when you are finished that all of bolts are tightened to at least 240 foot pounds. As for the hydraulic pressure you can remove the lift top and there is a screen inside the housing that may be stopped up but more than likely the auxilary pump is worn out. You can replace this pump for about 550.00 from TISCO but the tractor will have to be split behind the transmission housing. If you have not been into a Massey hydraulic system go talk to an experienced Massey mechanic or at least get a service manual. As there are several things that can be messed up by removing the lift cover.
