35 or 35x
Declan
02-18-2001 08:49:59
Would anyone out there be able to tell me the difference between the MF 35 and the MF 35x.The reason being that I have bought a 35 for restoration and I have no markings on it to tell which it is.
Clinton T. Chandler, Jr.
03-18-2001 06:49:49
 Re: 35 or 35x in reply to Declan, 02-18-2001 08:49:59
My 35 is a 1964 FE35 and it appears to have all the previously mentioned features. Six speed (3+high/low range). PTO with three positions including ground speed, Perkins 3cyl diesel, differential lock, and I can change gears on the move. So, is mine a deluxe? Thanks, C. T.
PIERCE FALLON
03-07-2001 14:36:36
the difference between the both is that ther is a differential lock on the 35x. the 35 and 35x have the same clutches (unless the tractor is really old!).I have seen many 35x s that have no multi power that was an option when buying but proved troubelsome. the diff pedal is located at the right trumpet housing (if sitting on).hope this helps.
garvas
02-20-2001 18:55:39
I own a 35 deluxe and recently purchased a 1963 parts book and a 1963 owners manual for the MF 35 Special and Mf 35 Deluxe.. Both books talk about the difference between a 35 special and a 35 deluxe but neither makes no mention of a 35 X. I have heard about the locking differentials and maybe this is the X series. In the owners manual the list of accessories available for the two 35's does not mention locking differentials, so there are probably all types of goodies yet to be heard of.
Mark
02-18-2001 17:27:43
I have an MF-35 Turf Special which is indicated on a plate on the lower part of dash. I found when I ordered parts for steering that they would keep sending me parts too small until I told the service man and he remembered my tractor parts were larger(heavy duty) never found out why.
Bill
02-18-2001 15:43:34
I am far from an expert but believe a 35 Deluxe has a ground speed power take off position and a Super Deluxe has in addition a locking differential lever. I am sure there are other changes which I am unaware. My Deluxe has six speeds and a three position power take off. If you can call OFF a position.
I'm guessing that there were three versions, Standard, Deluxe, and Super Deluxe.
Bill Stanley
Chris Massingham
02-23-2001 13:24:58
 Re: Re: 35 or 35x in reply to Bill, 02-18-2001 15:43:34
A 35X has mulitpower, which means you can change gear on the move. There is a small slide lever under steering wheel, 35`s have this part blanked off. 35x also has a PerkinsA3-152 engine.
