1085 shift problem
rhudson
02-22-2001 11:35:17
well its almost an antique! i have a MF1085 with cab. i can only change gears while the tractor is moving in the direction of the selected gear. in other words, if i'm in reverse but have come to standstill, i cannot shift out of reverse into any forward gear. if the tractor is in a forward gear but not rolling forward i cannot shift into reverse. i keep the ta out, have not tried it with ta. what gives? thanks
Dave
02-22-2001 19:40:56
 Re: 1085 shift problem in reply to rhudson, 02-22-2001 11:35:17
A 1085 Massey should have a Multi-power lever to the left side of the steering colum. It must be in low when shifting the main transmission. If it is in high you will not be able to shift, as you mentioned. When the tractor is in gear and you are moving you can shift to high muti-power, but make sure it is in low before you step on the clutch. Hope this helps, Masseydriver Dave.
kraig
05-13-2003 19:04:29
 Re: Re: 1085 shift problem in reply to Dave, 02-22-2001 19:40:56
Dave hit the nail on the head
kraig
05-13-2003 19:04:26
