1155
kd
02-25-2001 20:22:20
what are the weak points on a 1155 and what is one worth
Merle
02-26-2001 20:33:30
 Re: 1155 in reply to kd , 02-25-2001 20:22:20
kd The main weak point in the 1155 is the stub axles in the rear end. To check them drop the rear hyd oil filter, if metal flakes are present they are bad. One can cheat the system by pulling both rearends and swapping them from side to side. This is a one time good deal. By doing this, what gear surface you used going forward before swapping is now only used going in reverce. Why do they go bad IMHO to much HP for the rear end. This is the only weak point of this excellent tractor series that I can say I had trouble with. Cabs are solid and easy to get in and out of. Good Luck
Merle
timbo
02-26-2001 05:13:44
1155 is basically the same tractor as the 1105 and 1135 except the engine. I have a 1135 and I am well pleased. However some people do not like the V-8 engine that is in the 1155 but I personally have no experience with them. As for the price it could vary very much, total hrs., type and cond. of tires, cab or not, just general over all cond. Price could go from 4500.00 to 15,000.00.
kirk in ks,
02-18-2006 10:20:07
 Re: Re: 1155 in reply to timbo, 02-26-2001 05:13:44
the 1155,s are a good tractor, and really sound, your not gonna find anythig that will pull a good sized disk, or V blades like that Perkin,s V8, It just goes on and on,like it was nothing,
I have an 1155,and really like it alot real easy to run too,
not like the quadrange John deere,s,where ive run them and it,s cunfusing to find the right gear to run in the field,or so I thought,
kirk C
11-11-2004 20:03:57
I like 1150,s 1155,s and 2745,s too,Im looking for an 1155 no cab in decent mech cond, as I can do the rest,Paint,decal,s, etc,
And for a decent price too,
KC
