MF35 Standard Diesel glow plug adapters !
chris
03-07-2001 05:35:39
I bought a 1960 MF35 Delux with a 4 cyl. Standard diesel. Glow plugs were bad and all wires had been removed. The seller started it by pulling it off with a truck and it ran great. I made adapters to fit the cheap and common 10mm plugs into the 14mm hole in the block. I then made a simple harness and connected to the switch. The proof is in the results: it started great !!! Even this morning at 35 degrees(I just had to see if it would crank). The tools were under $50 and it took 2 hrs. on the lathe. The plugs are $6.99 at the auto parts store. Just wanted to share my results with anyone else who has been in my place.
Bruce
03-09-2001 21:08:34
 Re: MF35 Standard Diesel glow plug adapters ! in reply to chris, 03-07-2001 05:35:39
I also have a 1959 TO-35 with a 4-cyl standard diesel, my glow plugs are also shot. I would like to know what kind of plug you used and how you did this. Any help would be appreciated. Please reply a.s.a.p.
