175 massey
David
03-11-2001 08:06:49
My 175 does not have enough remote aux.power to lift operate the cylinder on the disc harrow. the hyd. oil is black, would changing oil help it work or is the aux. filter plugged. the multipower is working fine.
Big Dean
03-11-2001 08:45:57
 Re: 175 massey in reply to David, 03-11-2001 08:06:49
Most likely your auxiliary pump is bad.the auxiliary hydraulic and Multi-Power pump is a two-stage pump. It has two sets of gears the front part is for the Multi-Power the back part is the auxiliary hydraulics. It is not uncommon for the remote part of the pump to go bad and the Multi-Power to still work if I can be of further help Email me
David
03-11-2001 10:39:00
 Re: Re: 175 massey in reply to Big Dean , 03-11-2001 08:45:57
can the pump be rebuilt or is it better just to replace it with a new one? Which is the best way to go?
Big Dean
03-11-2001 14:35:02
 Re: Re: Re: 175 massey in reply to David, 03-11-2001 10:39:00
Most of the time the steel gears eat up the aluminum pump body I have never had much luck trying to rebuild them These pumps are pretty expensive About $400 the last time I looked.
Bill
03-11-2001 19:28:05
 Re: Re: Re: Re: 175 massey in reply to Big Dean , 03-11-2001 14:35:02
Big Dean, we are glad you are back.
Bill Stanley
Chip
03-12-2001 06:17:41
 Re: Re: Re: Re: Re: 175 massey in reply to Bill, 03-11-2001 19:28:05
Same here.
Chip
