135D clunking
jimmy
03-27-2001 03:28:21
I HAVE A 135D (NO MULTIPOWER) WHICH HAS A METALLIC
CLUNKING SOUND WHICH SEEMS TO COME FROM THE GEAR
BOX. IT ONLY APPEARS WHEN THE TRACTOR IS IN
NEUTRAL AND THE LIFT LEVER IS PULLED TO THE FURTHEST UP POSITION. IF YOU BACK OFF ON THE LEVER
AN INCH OR SO IT GOES AWAY. THE NOISE ALSO
DISAPPEARS IF YOU DEPRESS THE CLUTCH. COULD IT BE
THE HYDRAULIC PUMP OR CLUTCH PIN? HELP!
timbo
03-27-2001 06:01:03
 Re: 135D clunking in reply to jimmy, 03-27-2001 03:28:21
Sounds like the relief valve on the pump is popping off. The adjustment is probably off and the pump is going into constant pumping. Before going into the pump check the position control lever and see if it has a tab to keep the lever from going into constant pumping. This tab keeps the position control lever from going into constant pumping which you only need for operating auxilary cylinders.
