165 aux. hyd.
Stan
03-29-2001 20:21:47
Anyone have experience with the aftermarket aux. hyd. that mounts on top of the lift plate in front of the seat? I think it's just a selector so you can use 3-pt. or aux. , but not both at the same time. Mine 165 has no remote of any kind and I'm just looking for what-ever works. Won't be getting any really heavy use, maybe a wheel-type disk.
Stan
03-30-2001 08:47:11
 Re: 165 aux. hyd. in reply to Stan, 03-29-2001 20:21:47
Thanks guys. Appreciate your help. Good to see you back here Dean. I know life has some hard times to go with the good times. Good luck.
timbo
03-30-2001 06:12:44
Tractor Implement Supply C. (TISCO) makes a valve that works good, however you do not have the hydraulic flow that you do from the factory valve that uses the auxilary pump. But for a pickup cylinder on a trail type harrow or a haybine they do okay.
Big Dean
03-29-2001 23:17:34
Stan there are several different types of those valves and it makes a difference witch one you have as how it will work and you are right you can not use the remotes and the three point at the same time. If I can be of further assistance on this send me & email
