2805 PTO quit working
Bob
04-02-2001 11:53:02
I changed PTO shafts from 1000rpm to 540 rpm. The PTO was working last fall with the 1000 shaft but not now with the 540 shaft. The green light on the dash does not come on that tells that the PTO is engaged. The linkage is working on the side of the trans. Is there a valve that maybe sticking? Thanks Bob
Bob
04-04-2001 07:32:14
 Re: 2805 PTO quit working in reply to Bob, 04-02-2001 11:53:02
John you were right the 540 shaft didn't work. Put the 1000 shaft in and it was fine. Thanks Bob
John in SD
04-02-2001 16:43:17
How did you change the PTO to 540? I have a 2775. I understand that there is no 540 PTO offered for these big monsters. That is what my owners manual shows. Maybe the 540 you put in isn't meshing with any gears????
