M F 150 stuck in reverse
c taulbee
04-06-2001 07:58:40
Today I went to disc garden when I put Tractor in reverse It would not come out IT goes fine in reverse and hi and low works fine but I can not get the shifter to move.Does anyone know how to fix this? Thanks for any and all help. Charles
timbo
04-11-2001 05:55:29
 Re: M F 150 stuck in reverse in reply to c taulbee, 04-06-2001 07:58:40
Take the transmission filler plug out and look down in the transmission and you will see a square headed bolt where the shifter fork attaches to the shifter rail. Lock the brakes so the tractor won't roll and depress the clutch to take any pressure off of the gears, then take a crowbar and stick it agains the square headed bolt and slide it backwards or fowards until your gearstick will change the gears. All of this takes about 5 minutes.
Jack in NB
04-06-2001 13:11:41
Hello.
You have found one of the MF weaknesses. Shift lever wears a bit on the bottom (not surprising after 40 years...!), and can jump out of the socket - often on a quick shift, with a pull-up on the shift lever.
We correct the problem by removing the pin under the rubber boot on the left lever - about the size of a 3 1/2" spike (which works well for a punch too.... If you drive it out about 3/4 way, it's easier to drive back home.)
Remove spike. The shift lever should lift about a half inch. If it doesn't, drive the pin out a bit further.
Lift the shift lever, move it to the reverse position (left and forward) and let it down. It should seat into the hole and allow shifting. Replace pin and boot. Make sure the boot is seated all round - lets water in if you don't get it right.
You can see what's going on, if you can't find the hole, by removing the oil fill cover and looking into the transmission. You will see the square sockets for the end of the shift lever alongside one another on the shift castings; in reverse the knob on the end of the shift lever should be in the right rear hole.
Make sure the gasket is ok on the oil fill cover before replacing, or seal it with silicone bathtub caulking or equal. Lets water in if this is not checked.
S.Clark
04-09-2001 06:24:35
 Re: Re: M F 150 stuck in reverse in reply to Jack in NB, 04-06-2001 13:11:41
My MF35 stuck in first gear(low) yesterday. Is the procedure to fix this problem the same on the MF35 as it is on the MF50 ??
Thanks
John
04-10-2001 09:15:09
 Re: Re: Re: M F 150 stuck in reverse in reply to S.Clark, 04-09-2001 06:24:35
...Will described procedure for 150 diesel, stuck in reverse mentioned wrk on my 135. When lift foot on clutch it will only engage in reverse. adjustment to right for gear speed ok. Has perkins eng. Sure would appreciate help. Thanks JJ
To S. Clark and John - From Jack
04-11-2001 03:32:46
 Re: Re: Re: Re: M F 150 stuck in reverse in reply to John, 04-10-2001 09:15:09
The transmissions are pretty much the same, and the same procedure will work.
See also notes on Big Dean's tips board -
http://hometown.aol.com/daustin62/Bigdeantipindex.html
