PTO disengages
Chris Short
04-20-2001 03:19:09
I have an MF 135 Perkins diesel that has started to disengage the PTO when under load, ie when mowing thick grass. It is occasional but is becoming more frequent. Any clues? Thanks in anticipation.
Marcel from Saskatoon, Canada
04-20-2001 08:52:32
 Re: PTO disengages in reply to Chris Short, 04-20-2001 03:19:09
I have a 165 that does the same thing. Usually going down hill. Any suggestions or clues??
dustyhead43
04-21-2001 18:21:30
 Re: Re: PTO disengages in reply to Marcel from Saskatoon, Canada, 04-20-2001 08:52:32
sounds like there is a good bit of wear on the the pto stop spring and slide and possobly also on the lever and shift fork inside too. does it feel like it locks in place when you shift it in and out or does it move in and out of position with ease, if its with ease it will vibrate out fairly easy too, you wil need to get more spring tension on it if it move too easily
