Tractormeter tach needle
Brian
04-23-2001 19:47:09
The tractormeter records the hours OK but the needle jumps around erratically. Is the whole unit
shot or maybe the cable? Has anyone had this type of problem? This is on a 1960 MF35 134CI gas I bought on Saturday.....its a fine little tractor.
Thanks.
Tyler(WA)
04-24-2001 07:26:45
 Re: Tractormeter tach needle in reply to Brian, 04-23-2001 19:47:09
Could be a bad tach cable. Try removing it and cleaning it with some diesel with a pump oil can. You can force it in one end till it flows out the other. Make sure you take it off the generator and tach so both ends are free.
Once you have flushed out all the crud that accumulates there, put it back together and see if your problem goes away.
You also want to lube the tach and the generator, where the cable attaches. I use silicone spray because some plastics (if any parts are plastic) don't take petroleum lubricants well.
If the tach or generator drive is dry, it can chatter and give you readings like you're finding.
Good luck.
Brian
04-25-2001 04:57:34
 Re: Re: Tractormeter tach needle in reply to Tyler(WA), 04-24-2001 07:26:45
Tyler...Thanks a lot. I'll try that first before
before removing the actual unit.
