Cannister oil filter on MF 35 diesel
Bob
04-24-2001 09:21:42
My MF 35 diesel has the oil filter in the cannister (non-screw on). I replaced the filter recently and I wanted to know if there is a way to tell if I got it all together correctly. I replaced it exactly how it came out and there are no leaks. I am just not sure that the previous owner would have known any more than I do!
Thanks
Bill MD
04-24-2001 18:05:28
 Re: cannister oil filter on MF 35 diesel in reply to Bob, 04-24-2001 09:21:42
Hi, Just replaced the one on my 135 with the new type, cost about $30 dollars. Mine was missing parts and they say you can't get them any more. I didn't realize it was missing parts untill I bought a 165 and saw what should be there. When they are together right there is a clip that holds everything together so you can't lose parts or put it back together wrong. Bill
Mike
04-25-2001 19:29:06
 Re: Re: cannister oil filter on MF 35 diesel in reply to Bill MD, 04-24-2001 18:05:28
Bob,over the years as people change oil,parts
within the cannister fall into oil drain pans and
get pitched with the used oil.My 65 was missing
parts(also my 2085)all I did was install washers
and o rings so the oil flow actually goes through
the filter element instead of shooting straight
through the center hole of the filter!!!
