1155 hydraulics
David Reynolds
04-25-2001 12:21:24
On my 1155, when I use the remotes or three point hydraulics, I loose part of the power steering or sometimes all. Any suggestions what might be wrong? I suspect the priority valve. Any test that I could do to isolate the problem?
chuck
04-25-2001 18:18:30
 Re: 1155 hydraulics in reply to David Reynolds, 04-25-2001 12:21:24
I have two MF1135s with the same hyd. system &
also notice the same thing.One has a 2 spool rem.
I hooked to a loader & the other has a 1 spool I
use for different aux. stuff & both effect the
power steering. I thought It was a normal condition sense both
my MFs do it.None of the MF dealers around here
know anything about larger tractors so maybe we
will both get lucky & get a answer.
Floyd Gutierrez
11-12-2001 07:31:03
 Re: Re: 1155 hydraulics in reply to chuck, 04-25-2001 18:18:30
I have a 1155 with the same problem and haven't figured out the problem - am looking for a parts and service manual - any help would be appreciated
