Throttle linkage on MF35 gas
Brian
04-28-2001 20:11:49
When I pull the throttle lever all the way down it
doesn't stay put; it springs back up to a lower RPM level. Is this part of the governor mechinism?
Sometimes I need the hammer down for a few minutes and its frustrating that I need to keep my hand on
the lever.
Thanks for any info.
Thyge
04-29-2001 15:00:36
 Re: Throttle linkage on MF35 gas in reply to Brian, 04-28-2001 20:11:49
On my '35 is a spring loaded friction disc behind the dash. loosen the clamp & compress the load spring a little more - voila!
Thyge
Taageskov
Denmark
Brian
04-29-2001 17:39:27
 Re: Re: Throttle linkage on MF35 gas in reply to Thyge, 04-29-2001 15:00:36
Thanks. I will try that. I didn't think I'd have to go that far to get help. Hope all is well in Denmark.
Thyge
05-01-2001 14:51:01
 Re: Re: Re: Throttle linkage on MF35 gas in reply to Brian, 04-29-2001 17:39:27
Yup!
It is mainly in old poetry, that something is rotten in Denmark.
Aren't you paying quite an overprice for your 35's overthere? I paid just about $250 for my 3 cyl. diesel - allright, I had to do some work on it, but less than $100 worth, so...
My 35 Standard gas cost me $50 plus a case of beer. I got my TE-A20 for driving it away - Yes, it moved under its own power, no rework done!
Thyge
Brian
05-02-2001 12:34:32
 Re: Re: Re: Re: Throttle linkage on MF35 gas in reply to Thyge, 05-01-2001 14:51:01
Yes. We sure are compared to you. I live in southern Ontario just south of Windsor and I paid $5000 Cdn for a MF35 gas with a loader. This is considered a reasonable price for the tractor. It runs real well but I need to fix the gas guage and tractormeter. These replacement parts are very expensive. Maybe I should try sourcing the parts from Europe. But I still like the little tractor.....she's not pretty but works real good.
I was in Europe in 1999 but didn't make it to Denmark. I hope to visit some day.
