MF35 axles
Chris C.
04-30-2001 17:23:07
Thanks to all for the help on removing outer bearings from axles. I ended up cutting the cage with a carbide pencil grinder and picking out the rollers. This let the carrier with the outer race slip off, then I cut a notch in the inner race with a cutoff wheel and cracked it off with a chisel! I just wasn't comfortable with anyones ability with a torch near me.By the way if you are thinking of using a speedi-sleeve on the axle where the outer seal runs try $57.00 each! Hello JB Weld!
