Leaking Hydraulic cylinder
Chris B
05-01-2001 10:44:15
My MF 135 has a MF 235 loader mounted on it, and one of the hydraulic cylinders on the loader developed a serious leak (at the seal) today. There was only light seepage until today. Can the seal be replaced, or am I looking at a new cylinder? How expensive will this be?
Tyler(WA)
05-03-2001 07:35:35
 Re: Leaking Hydraulic cylinder in reply to Chris B, 05-01-2001 10:44:15
Dean's right... as if I ever had to say THAT.
You can replace the seals in a typical cylinder for under $20 (USD).
Check the gland too. That's the front seal that the shaft goes through. If it's out of round (the hole) it will wear out the new seals fast. You can get new glands fabricated at a good full service machine shop or you might be able to order one from ACGO. Let your wallet be your guide.
I've rebuilt 4 cylinders with no trouble. There isn't anything to the insides.
Big Dean
05-01-2001 13:25:44
You can replace the seals in that cylinder. I would check the polish rod I have seen a lot of them bowed if it is bowed the seal will start to leak again in a very short time.If it even stop at all.
