Pump speed gpm vs backhoe pump speed rating
Bill
05-03-2001 05:23:37
I have a question regarding pump speed vs. the recomended pump speed of an attachment. I have a Massey 35 utility. It has a front mounted pump rated at 17 gpm. I have a hoe that has a recommended pump speed of 5 - 10gpm. Will this cause any problems? when I hook the hoe to the machine and switch the hydradic valve from the bucket to the hoe the engine does change pitch. I can tell it is working a little harder but it runs fine. Also what rpm should I run the engine at? It is a mid 1950's gas model. I have been running it at recommended pto speed I think about 1250 rpms. At this speed the hoe will move a little fast but it is very controlable. Thanks, Bill.
