1967 MF 35 with Power Steering that doesn't work
Don Shipman
05-19-2001 19:41:27
My MF power steering system has stopped working. I have checked for pressure at the pump, and both cylinders at the wheels, all is ok. Once in a great while the power steering will work for a couple of minutes and then stop again. Is there something in the steering box or sector that could cause this? Possibly a check valve some where! Any help would be appreciated. It is very difficult to drive with no PS. This is a gas model engine.
Don
07-04-2001 18:25:54
 Re: 1967 MF 35 with Power Steering that doesn't work in reply to Don Shipman, 05-19-2001 19:41:27
More than likely your problem is in the steering valve located in the steering column. It could be something as simple as a leaking o-ring. The column must be free to float up and down a small amount as this is what triggers the valve. Check the wave washers at the valve. Replace if needed. I assume you have checked for a hose that is collapsing internally. Good luck.
