150 with hydralic control valve
RICK GRANT
05-20-2001 03:51:11
hi all i recently bought a 150 it has a hydralic control valve for remotes which is good but in order to operate the lift arms i have to do it with the valve. for example if i want to raise the lift arms i have to put the position control lever in the raise position and then use the control valve to raise the arms .then to lower them i have to do the opposite lower position control lever then use the valve lever .this makes it almost impossible to use a blade because your trying to use the two levers to raise and lower it . i was going to just take it off but one of the bolts rounded off it was full of crud and water . i can torch off the bolt head but will destroy the valve in the process.need help in ohio. thanks
