175 shifter hung in neutral
Jack
05-28-2001 17:02:47
175 shifter hung in neutral position and cannot get into any gear.It is really stuck and it did it while idling in neutral.What needs to be done to unhang it?Thanks.
TAZ1206
06-07-2001 22:06:05
 Re: 175 shifter hung in neutral in reply to Jack, 05-28-2001 17:02:47
HI,YOU DIDN'T SPECIFY WHICH LEVER STUCK ,I ASSUME THE RIGHT SIDE.PRY UP RUBBER BOOT AT BASE OF LEVER ,REMOVE SNAP-RING;LIFT OUT LEVER. SHIFTER-SHAFTS ARE NOW VISIBLE. BE SURE NOTCHES ARE PARALL . LUCK TO YA TAZ
