135 diff lock
rob
06-03-2001 04:04:46
I HAVE A 135 WHICH WHEN YOU ENGAGE THE DIFF LOCK IT DOES NOT DO ANYTHING. CAN THE DIFF LOCK BE GOT AT BY REMOVING THE RIGHT SIDE TRUMPET AND WHAT SHOULD I EXPECT TO FIND .MANY THANKS FOR ANY INFO ROB
Bob
06-03-2001 15:59:57
 Re: 135 diff lock in reply to rob, 06-03-2001 04:04:46
The diff lock is serviced by removing the axle housing. I strongly recommend you obtain a service manual first! Available from several of the sponsors of the site.
Does the shaft turn? i is very common for the shaft to tightly rusted into the housing. You will need to disassemble for diagnosis and repair. A chain hoist, or strong assistant is needed to reassemble!
