MF 65 Clutch Shaft Position
Chris R. Mazzit
06-07-2001 11:52:40
I have a Massey 65 possibly with a clutch fork slipping on the clutch shaft. Everytime I adjust for 1/8" free play on the clutch bellcrank and step on the clutch pedal to apply both clutches, I loose adjustment and end up with excessive free play. Does anyone know where the pry bar hole position belongs on the shaft? It seems like it is moving clockwise and is presently at 2/8 o'clock. I marked the bell crank and shaft...the marks stay aligned when I apply clutches.
Chris C.
06-08-2001 09:00:50
 Re: MF 65 Clutch Shaft Position in reply to Chris R. Mazzitti, 06-07-2001 11:52:40
On my 35 (dual clutch) the hole runs almost 12/6 o'clock You may have the two set screws on the release bearing fork coming loose allowing it to rotate on the shaft. Fortunately, these can be accessed through the lower access plate under the bell housing. They should be safety wired after tightening, hope this helps
