MF 165 Perkins Engine Number?
Brian Silvey
06-17-2001 12:00:15
I can't seem to locate the engine serial # to determine it's size. Can someone please direct me on where to find it. I looked below the coolant inlet for the engine and only found the casting number. I looked above it but didn't find any other numbers. I need a fuel pump for it and there are more than 1 Diesel Perkins engines listed for this model. Any help would be appreciated. thanks.
Wayne
06-28-2004 07:42:23
 Re: MF 165 Perkins Engine Number? in reply to Brian Silvey, 06-17-2001 12:00:15
There should be a number embossed on to the engine to the right of the diesel filters. It is only a few letters / numbers long, something like A 14D (thats what i think mine is). However, if for some reason the number isn't on there, look above your rev counter and there should be a small metal plaque. On that you should have a serial number. Jot that down and take it to a massey dealer. They will then be able to tell you the exact parts you need for your tractor.
rick
06-17-2001 19:38:56
The ser.# should be stamped on the left side of the block just below and behind the rear exhaust port. The model# is on a tag on the air intake manifold. Rick
