STARTERS from the 101 Super and the 101/102 Senior
A QUESTION ????
Alberta Mike
06-20-2001 12:17:31
Actually, I'm trying to find out whether or not the starters on these two Masseys are the same, or at least interchangeable. Do both of them use the big, heavy-duty push start button on the dash, or does one of them have the remote mechanical rod that pushes the button contact that is on top of the starter? Could a starter from a Senior be used on the Super? I know that they use different engines, but I think the clutch housing and flywheel might be the same. Any model numbers of the Auto Lite starters would also be appreciated. Thanks for you help.
mh malcom
07-15-2001 10:13:29
 Re: STARTERS from the 101 Super and the 101/102 Senior - A QUESTION ???? in reply to Alberta Mike, 06-20-2001 12:17:31
The 101 Super with Chrysler engine has the remote mechanical rod that pushes the starter mounted button. the starter is an Auto-Lite and the number on the tag is maw-4013-a 6-s003582. I believe the starters on all these early Chrysler engines are the same. Continental engines probably have different starters. Hope this helps.
