Perkins from super dexta in M-F 135
carl
06-20-2001 16:13:36
I have a M-F 135 with a very destroyed 3 cyl Perkins diesel;my neighbor has a wrecked super dexta ford with a 3 cyl Perkins; will it fit my M-F? Thanks
pierce
06-24-2001 17:08:15
 Re: Perkins from super dexta in M-F 135 in reply to carl, 06-20-2001 16:13:36
As far as i know the dexta engine has no place for a lift pump on the block i have both engines and have studied them carefully and i know that the dexta runs on air draught. also the 135 has a different head to the 35 (dexta engine)so that wont work either.sorry! let me know how u get on
smokey
06-21-2001 17:52:51
I have the same problem. My straight axle got burnt badly. Trying to obtain a complete 3-152 is almost impossible. My assumption is providing you use the MF sump you should be ok. Be carful mixing parts from a AD3-152 and a A3-152 - same block but pistons, injectors and fuel pump are different. I have a perkins 3-152 and MF148 factory manuals. Please let me know how you go.
