Pony
brian salyers
06-22-2001 10:22:12
I HAVE A MH PONEY THAT I NEED TO KNOW WHERE THE SERIAL NUMBER IS. I NEED TO FIND OUT WHAT YEAR IT IS.
John K tHOMPSON
05-12-2003 17:50:59
 Re: pony in reply to brian salyers, 06-22-2001 10:22:12
While removing the engine of my pony for repairs the driveshaft spline pulled out of the transmission. What is the trick to getting that splined shaft back into the female spline in the transmission. I will be ever so greatful for a tip. John K Thompson
Jason in Pa
06-22-2001 15:49:10
If you are facing the front part of the tractor it is on the left side along the frame rail. Up near the radiator. There is a plate that shows the serial# for the Continental engine on the right side of the block as well but that will not tell you the year of the tractor. If you find the number let me know and I can look the year up for you.
