255 noise
fieldman12
06-24-2001 01:51:33
I have a 1976 255 diesel that has an 8-speed transmission. I seem to have backlash in forth gear that makes a noise no matter whether the tractor is in low or high range. When in forth gear I sometimes hear a very obvious noise for a second that sounds like it is coming from the transmission when idling down the tractor while driving. The noise does not appear to happen in any other gear. Are noises from the transmission and rear end common on this model? We have a 165 MF diesel that is similar that seems to be pretty quite in the transmission and rear end. The 165 also has an 8-speed transmission that appears to be the same as the 255 except forth gear is in a different place than on the 165.
Thanks,
Fieldman12
