MF35 Exhaust smoke
Bill
06-30-2001 19:47:43
I just had a broken camshaft and governor replaced on my MF35. I picked it up this morning. It runs pretty good now (starts quickly, idles smooth, pulls well under load) ... but it has a lot of exhaust smoke under load. The folks who did the repair say they're sure they couldn't have done anything that could cause it to smoke like it is and said just use it and it may clear up after a little awhile. As far as I can tell, all they did was remove the gas tank and rocker assy, and then pull the front cover off to R&R the governor and camshaft. This afternoon I pulled the spark-plugs and they have oil on them, the worst being #4. Checked the compression and it's the same as it was a few months ago (120-130) with #4 being on the low end. Cleaned everything up and put it back together, same thing ... smokes under load. Any ideas where the problem might be?
Thanks, Bill
