1969 MF-201 three point hitch problems
Jack M.
07-10-2001 12:23:43
Help!! I have a 69 model 201 and the three point hitch is not funtioning right. The only time it will go up is when the tractor is in gear and moving. It goes up and stays tight against the rear axle housing. The controls seem to have no effect on it at all. It will not hold any load if the tractor is not in gear. It is a shuttle shift transmission. Also, although the transmission housing has a shift pattern imbossed in it for three speeds forward and one reverse, I only can get what seems to be second and third. Thanks for any help or comments.
