MF35 One Wire Alternator
C. T. in Oklaho
07-18-2001 19:02:05
I want to install a 1 wire alternator without damaging the original generator bracket. Is an adaptor available?
Rick in NC
07-20-2001 10:55:11
 Re: MF35 One Wire Alternator in reply to C. T. in Oklahoma, 07-18-2001 19:02:05
C.T.,
I would not use the one-wire arrangment unless the motor on your tractor will rev high enough to cause the alternator internal exciter to activate. Maybe the MF 35 will rev higher than my A-C Model B, but I had to go to the 3-wire alternator because the motor on the little A-C would not rev high enough to get the alternator to start charging.
I put on the 3-wire and the thing starts charging the minute it starts. The one-wire is a little simpler, but not as flexible in my small experience.
Good Luck.
Tyler(WA)
07-19-2001 06:18:03
I installed a Delco 10SI (actually a Japanese alternator that was smaller diameter but had same lug pattern) and used the old generator bracket on my MF-2135 (135 industrial.) I cut some 1/4" pipe to make spacers so the long bolt wouldn't squeeze the bracked out of shape when I tightened it up.
Simple and it worked fine.
C. T. in Oklahoma
07-19-2001 16:52:45
 Re: Re: MF35 One Wire Alternator in reply to Tyler(WA), 07-19-2001 06:18:03
Thanks Tyler.
C. T.
Alan
07-19-2001 17:45:16
 Re: Re: Re: MF35 One Wire Alternator in reply to C. T. in Oklahoma, 07-19-2001 16:52:45
Just a couple of suggestions: 1. If this is a
tractor that you don't run very often (once a week
@ least), do not use a single wire setup. The
field wire will drain a battery.(my experience) 2.
MAKE SURE the belt lines up before
starting/revving the engine. Even a belt can
damage a radiator when it gets tangled in the fan.
(Happened on a used car I bought.) If you need a
wiring diagram for using a 3 wire internally
regulated Delco, e-mail me & I'll send you one I
found. If you find another make sure the field
line (F) or (2) is on a switched line or you'll
have the same drain.
Good luck & email w/questions - ALAN
P.S. your belt adjuster may need to be longer,
often one from an older car has more throw. We
used one from an old Dodge Duster.
Dave
06-17-2002 08:18:38
 Re: Re: Re: Re: MF35 One Wire Alternator in reply to Alan, 07-19-2001 17:45:16
anyone know how to wire a delco alternator with a external regulator the alternator has 2 brush wires and a pos and neg wire its on an old gas powered 3 cylinder mf:-)
