MH 44 GS starting troubleshooting
caseguy
07-22-2001 21:57:39
4 months ago a new 6 volt battery. Yesterday- I removed the starter- 6 volts run it fine-no apparent excess draw- remount- and I get nothing (not even a click) when I press the starter button on the dash. I removed the starter switch and sprayed the button and cleaned it up today- now I get current through the switch- but not enough to turn the motor over; even with a newly charged battery and a booston the side. I checked all the battery cables- they are clean and free of shorts. The starter cable is original and was frayed but is now repaired and taped. It is a positive ground and the system seems to be loosing or drawing a lot of power though. I have only used a test light to follow the power through this system. The keyswitch is wired in after the amp meter which draws off the power side of the starter switch. The other side of the starter switch runs to the starter. The switch looks as if it may have gotten warm once. When the tractor runs- the amp meter works. Do I get the starter overhauled or replace the cables or the starter switch or all the above? The ground strap appears to be functioning fine and the connections have all been cleaned and checked. I'm still using the crank to start the engine. The starting is intermittent at best. Does anyone have some input?
TAZ1206
08-03-2001 16:47:05
 Re: MH 44 GS starting troubleshooting in reply to caseguy, 07-22-2001 21:57:39
FROM PAST EXPERIANCE REPLACE START BOTTON.LUK 2 YA TAZ
