1135 reverse problems
Dan W
07-24-2001 17:57:47
I put away my 1135 last night with no problems. Went to back it out today and it won't go into reverse. All forward gears are okay. It doesn't appear to be a clutch problem. Is there a pin or spring that could be broken or loose? Nothing is obviously apparent.
Stanley Graham
09-12-2003 12:24:06
 Re: 1135 reverse problems in reply to Dan W, 07-24-2001 17:57:47
Look under the cab were the linkeg is and see if there is a bird nest in the road.
Stanley Graham
09-12-2003 12:17:23
Look under the cab were the linkege is for a bird nest. Our 1105 massey did the same thing
Stanley Graham
09-12-2003 12:11:47
Look and see if there is a bird nest under the cab. Our 1105 Massey had the same problem
