Wiring for headlights on MF35
Brian
07-31-2001 18:41:02
If you want to replace the headlights and by-pass the ignition and just use a switch, where does the hot wire get connected? I realize that there is a chance of leaving the lights on but I think this is the easiest way to go.
Thanks, and hoping to see the light soon.
Big Dean
08-02-2001 06:57:24
 Re: Wiring for headlights on MF35 in reply to Brian, 07-31-2001 18:41:02
Brian If you still have the original charging system on your tractor the L terminal on the voltage regulator. [2] either one of the terminals on the ammeter [3] the battery side terminal of the solenoid
Brian
08-02-2001 08:15:20
 Re: Re: Wiring for headlights on MF35 in reply to Big Dean, 08-02-2001 06:57:24
Thanks Big Dean
