MF40 Industrial Loader engine oil drips from weep hole
Branko
08-09-2001 08:23:35
When the engine is running I get a steady stream of engine oil leaking from the weep hole beneath the bell housing area. (This is definitly crankcase oil and not transmission oil). What could be the cause of this?
mike
08-09-2001 12:45:17
 Re: MF40 Industrial Loader engine oil drips from weep hole in reply to Branko, 08-09-2001 08:23:35
Rear main seal is leaking.That's the purpose
of the hole,when you get a tranny or rear main
leak the oil runs out instead of building up
and getting into the clutch.It will need to be
split to fix.
Branko
08-09-2001 22:37:15
 Re: Re: MF40 Industrial Loader engine oil drips from weep hole in reply to mike, 08-09-2001 12:45:17
Thanks for the info. I was told that it could be the pan gasket. How can one tell without splitting the tractor?
