#10 MF Hay Baler
Gordon Melancon
08-11-2001 07:15:23
I just recently purchased a #10 MF hay baler at an auction. I am in the need of a manual as to the operation of this equipment and the problems that I may have. If any one can tell me as to where I might be able to purchase one, I would be grateful.
bscw1234
05-11-2006 18:49:48
 Re: #10 MF Hay Baler in reply to Gordon Melancon, 08-11-2001 07:15:23
Benning Implement at Effingham, IL They have forgot more about these balers than most people know! They are also a Massey dealer. The original question was when were these # 10 balers made?
Tommy Rushing
03-06-2006 07:59:44
WHEN WAS THE MODEL 10 HAY BAILERS MADE
THANKS
TOMMY
Hughie the farmer
08-01-2002 08:18:13
I have a number 9 hay baler and i was wondering if anyone knows anything about how to use it. What i want to know is how to get it to tie on the right side.
Travis Schaub
08-07-2002 19:28:29
 Re: Re: #10 MF Hay Baler in reply to Hughie the farmer, 08-01-2002 08:18:13
Make sure the surroundin area around the tiers are clean. Losen up the bale the tenson bolts step 1 feed through the needles on the bottom of baler. step 2 make sure all string is out of tieing area figers and ect. step 3 run baler and trip the tiers. step 4 make sure that the fingers are still clean and no twine is stuck in fingers. If all is done right baler should tie. Make sure u grease the knoters with 1 squirt only so u don't reck the seals
Ger
05-17-2004 15:48:43
 Re: Re: Re: #10 MF Hay Baler in reply to Travis Schaub, 08-07-2002 19:28:29
I have a MF #9 baler and am looking for information on it. Anyone out there who may know how to find an electronic manual.
mitch sahnow
04-21-2005 20:12:00
 Re: Re: Re: Re: #10 MF Hay Baler in reply to Ger, 05-17-2004 15:48:43
i am looking fo anyone that can help me with a MF #10 baler i'm looking for a repair manual or a manual of some sort to set the baler to work
jbrazier
09-06-2005 12:06:04
 Re: Re: Re: Re: #10 MF Hay Baler in reply to mitch sahnow, 04-21-2005 20:12:00
I need #12 baler manual
Tony Cooksey
05-19-2002 15:10:44
I have a #10 MF Hay Baler and I am also looking for a manual. I also need a bale length spindle for this model. Have you had any luck finding parts?
Travis Schaub
08-07-2002 19:31:09
 Re: Re: #10 MF Hay Baler in reply to Tony Cooksey, 05-19-2002 15:10:44
I am lookin for a plunger bearing and bearing holder for a massey 10 if u know anyone with parts please email me
ave kennedy
07-14-2002 23:04:09
I would like to get some information on a model 12 massey ferguson hay bailer on the knotter not tieing the bails properly all the time,skips one side once in a while the right side once every six bails and why I can not use the old type twine instead of the plastic type twine. Where and how I can obtain manuel for this bailer Thank you Ave kennedy, 2519 Washburn Road RR#2,Inverary Ontario KoH-1Xo
ave kennedy
07-14-2002 22:59:39
George From Ontario
08-12-2001 12:32:18
I got my manual for my #10 Baler at the Local Massey Dealer about 5 years ago .Lost the original in a fire.
Hope this helps .
George
