Cast spoke wheel hubs on a Massey ???? Make sense to anyone ???
Alberta Mike
08-27-2001 21:54:18
A friend of mine recently picked up a Massey 101 Super, wide front. The rear cast hubs are cast iron but spoked, six spokes each of which is rectangular in cross section. The spokes are about 3/4" thick and 3" wide and there are six of them. The wheel rims have been cannibalized from some other tractor and they have a mounting lug welded onto the rim. The rims bolt right up with regular bolts to the hub, not the typical Massey type of nut with the square tapered head. They gotta be Massey because they bolt right up to the tapered axel shaft like on all the full-hub cast iron hubs. Anybody know of any Masseys that had this set-up? I was thinking maybe some old stock of some type was used up on some of them at the factory. Were any of the earlier Masseys or Wallaces of this type?
LilCritter
09-10-2001 14:53:33
 Re: Cast spoke wheel hubs on a Massey ???? Make sense to anyone ??? in reply to Alberta Mike, 08-27-2001 21:54:18
Sounds like someone was looking to shave some weight off the thing, like mabey a tractor puller or something. I tried it on a 33 but have moved up sence then.
